enable isis restart-helper
Description
This command enables the IS-IS router to act as a restart helper according to draft-ietf-isis-restart-02—Restart signaling for IS-IS.
Syntax Description
Default
Enabled.
Usage Guidelines
None.
The following command enables the IS-IS restart helper:
Platform Availability
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
